Cyclone 10 LP True DPRAM IP
In Cyclone 10 LP device, TRUE DPRAM IP with single clock is not writing on the odd addresses why is it so
- kmalaww
ssdsd
- kmalaww
I’ve seen a similar issue before. I’m also facing something similar while working on Secrets Behind the Destiny Matrix. In most cases, it’s related to configuration, address mapping, or input settings. It may be worth checking those areas first.
- kmalaww
I’ve seen similar issues in my own projects as well. I faced something like this while working ong Grade Calculator for Students. In my case, it was related to configuration and input mapping, so that may be worth checking.
- ShengN_altera
Could you provide design for taking a look?
- Annu
My RAM is accessed by a Processor where processor is trying to write byte by byte But My RAM is word based. If we try writing byte by byte, does it corrupts the RAM
- ShengN_altera
Yes, a word-based RAM expects aligned word writes, not arbitrary byte writes — unless byte enable is properly handled. You have to properly use the byte enable like for example (2'b11 for 16 bits)
Take an example:
Assume:
- RAM width = 16-bit (2 bytes)
- Addressing = word-based
Address mapping:
Processor addr RAM addr Byte lane 0 word 0 low byte 1 word 0 high byte 2 word 1 low byte 3 word 1 high byte If your design:
- Always writes full word
- OR only enables byteena[0] (
If byte enable is missing or wrong)
Then:
Address Result Even (0,2,...) writes lower byte Odd (1,3,...) upper byte ignored You may check the waveform for byteenable from this doc https://cdrdv2-public.intel.com/654378/ug_ram.pdf (page 39)
- ShengN_altera
May I know does your problem resolved?
