Annu
3 months agoCyclone 10 LP True DPRAM IP
In Cyclone 10 LP device, TRUE DPRAM IP with single clock is not writing on the odd addresses why is it so
Annu
3 months agoMy RAM is accessed by a Processor where processor is trying to write byte by byte But My RAM is word based. If we try writing byte by byte, does it corrupts the RAM
ShengN_altera
3 months agoYes, a word-based RAM expects aligned word writes, not arbitrary byte writes — unless byte enable is properly handled. You have to properly use the byte enable like for example (2'b11 for 16 bits)
Take an example:
Assume:
- RAM width = 16-bit (2 bytes)
- Addressing = word-based
Address mapping:
| Processor addr | RAM addr | Byte lane |
| 0 | word 0 | low byte |
| 1 | word 0 | high byte |
| 2 | word 1 | low byte |
| 3 | word 1 | high byte |
If your design:
- Always writes full word
- OR only enables byteena[0] (
If byte enable is missing or wrong)
Then:
| Address | Result |
| Even (0,2,...) | writes lower byte |
| Odd (1,3,...) | upper byte ignored |
You may check the waveform for byteenable from this doc https://cdrdv2-public.intel.com/654378/ug_ram.pdf (page 39)
