aaecl's avatar
aaecl
6 months ago
Cyclone 10 GX Startup Time Support
I have been utilizing Cyclone 10 GX (10CX105YF672E6G) FPGA for some time but now I require the FPGA to startup and run as fast as possible, I know there is a hard limit caused by flash communications...
  • Farabi_Altera's avatar
    5 months ago
    Here are some recommendation to minimize the bootup time.
    1- use fast flash - ASx4 or FPPx8 Flash is fastest
    2- compress bitstream - can reduce up to 60% of original bitstream size
    3- increase flash clock frequency - 100 to 166MHz if possible
    4- optimize power ramp up time - VCC/VCCPT/VCCA can go as fast as 1-2ms(normal 5-10ms) while still meeting the spec
    5- use Fast POR mode
    regards,
    Farabi
