12 years ago
CYCLON IV GX - ALTGX Won't recieve any valid data
Hello
I'm new in the forum, seems like very nice one
me and my partner working on a final project for the university engineering degree. We have designed and manufactured two printed circuits implementing a serial connectivity based on optical fibers. Optical transceivers connected to the dedicated high speed transceivers pins.
we're having difficulties getting the transceivers to work.
We are trying to transmit 8bit data from one board to the other. The data is 55h repeatedly in the transmitter side but all we get in the receiver side is FFh all the time, never even a piece from the original data.
The receiver is configured with low-latency PCS. We also never get rx_freqlocked asserted, even after a reset sequence as described in the handbook in the transceivers section. CDR lock mode is auto.
The acceptable ppm between the pll reference clock and the CDR clock is 300 on both sides (receive and transmit), also the pll_inclk is differential 100MHz on both sides. System clock on both sides is 100MHz.
Maybe someone have an idea how to solve this problem?
