13 years agoCYCLON IV GX - ALTGX Won't recieve any valid data
Hello I'm new in the forum, seems like very nice one me and my partner working on a final project for the university engineering degree. We have designed and manufactured two printed circu...
13 years ago --- Quote Start --- (we also bodged a 2kohm resistor on two vias under the fpga) now we just need to get the sync right and we can start moving data! dave, thank you so much, we have been stuck on this issue for two weeks! --- Quote End --- Nice work! Don't ever get frustrated by these types of problems. These are actually the *best* type of problems to have. For example, would you have ever read the data sheet properly if you didn't have this issue? Now when you interface between two standards, you will know to look at the common-mode voltage (and the peak-to-peak voltage). Good luck with your testing! Cheers, Dave
