16 years ago
Config 1S25 using CPLD
Hi,all
I'm tring to use a CPLD to config EP1S25 in PS mode. I've see the datasheet and here's my promblem. When CONF_DONE goes high and config is done, do i need continue clkpulse on the DCLK pin befor INIT_DONE goes high? if so when INIT_DONE goes high , need the DCLK stop immediatly ? or is it ok to continue 1 or 2 cycles on DCLK pin?
thanks
    The only information i am aware about DCLK after INIT_DONE is that DCLK must not float and it doesn't matter if it stays 0 or 1
    The answer to the first question is yes (as far as I know), to the second is surely no. In multiple FPGA configurations schemes, DCLK can be shared between mutiple devices and is ignored before and after configuration.
