14 years ago
Clock recovery from signle 125MHz pulses with PLL
I have a circuit that uses one PLL to recover data and clock from a single bitstream. This PLL is fed with 125 MHz clock, on it's output there is 375 MHz clock (which is used for the circuity of data and clock recovery).
From this data there are recovered 125 MHz pulses every 44.1 kHz (sync pulses). I would like to recover this 44.1 kHz clock from the bit stream. (for audio purposes - to match the clock of the data - if internal 44.1 clock is used form the generator there are some bad effects in the sound).
My questions are:
1) Can i simply feed those pulses into the second PLL module to recover the data ?
2) Are there any other considerations that i should think about ?
thanks
madness123
    the family is Cyclone III - 5k LE.
    As kaz has written i already have 44.1k sync pulses from data itself.
    I put the data bits into the shift register, and then:
    sync_detect : process (clk_125_in, shift_register)
     begin
      if clk_125_in'event and clk_125_in = '1' then
            if ((shift_register(14 downto 5) = "1100010001") and (shift_register(4 downto 0) /= "11000")) THEN
               synchronized <= '1';
            else
               synchronized <= '0';
           end if;
      end if;
     end process sync_detect;
    So my questions are once again :).
    1) From the data i get synchronized pulses every 44.1kHz. I would like to and have to make a clock from this, I even would have to if neccessary multiply it by 2 or 4 to get 88.2 or 176.4k for different modes.
    That's why i'm thinking about PLL. Can i simply put them in the PLL or should i do smth with them as kaz has written.
    2) I had ocasionally problems with fan-outing this signal to the other parts of my design - i suppose that due to CDR there were some problems.
    Could i simply put there another signal like synchronized2 to double up the logic, but to get the second signal and not to mess with the synchronized? Or am i saying stupid things?:)
    best regards
    If I understood you, you already have pulses at 44.1KHz possibly generated from a counter or sync pulse. You want to generate 44.1KHs from data itself.
    I suggest you use simple averaging filter(just accumulator) to remove high frequency.
    i.e. add up samples for some suitable total that will build up then come down to zero as the stream stops at zero. You should then get sort of triangular
    pulses at 44.1KHz then apply a comparator to get cleaner pulses.
    As far as I understand, the 125 MHz is already recovered from the data stream. Then the 44.1 kHz detection problem hasn't to do with clock recovery, it's about detecting a sync pattern.
    What's specific to the 44.1 kHz pattern that allows to distinguish it from the data stream?
    By the way, what's the involved FPGA family
    Hi FvM,
    The Clock and Data Recovery works fine, perhaps it's not done with best practises but it works with no problems.
    I have the question about pulses that are generated from this data (their source doesn't really matter) -> can i recover a clock from pulses occuring approx. every (1/44100)s.
    best regards
    madness
    The bitstream encoding details aren't very clear in your post. But generally speaking, regular Altera PLLs aren't designed for CDR purposes. They require a continuous reference clock to synchronize on it. Depending on required clock tolerance, there may be a chance to implement a CDR scheme based on PLL dynamic phase shift in user logic. Newer FPGA families with hardware SERDES are also implementing a software CDR feature.
