14 years agoClock recovery from signle 125MHz pulses with PLL
Hi, I have a circuit that uses one PLL to recover data and clock from a single bitstream. This PLL is fed with 125 MHz clock, on it's output there is 375 MHz clock (which is used for the circuity ...
14 years agoThe bitstream encoding details aren't very clear in your post. But generally speaking, regular Altera PLLs aren't designed for CDR purposes. They require a continuous reference clock to synchronize on it. Depending on required clock tolerance, there may be a chance to implement a CDR scheme based on PLL dynamic phase shift in user logic. Newer FPGA families with hardware SERDES are also implementing a software CDR feature.
