14 years agoClock recovery from signle 125MHz pulses with PLL
Hi, I have a circuit that uses one PLL to recover data and clock from a single bitstream. This PLL is fed with 125 MHz clock, on it's output there is 375 MHz clock (which is used for the circuity ...
14 years agoHi,
the family is Cyclone III - 5k LE. As kaz has written i already have 44.1k sync pulses from data itself. I put the data bits into the shift register, and then:
sync_detect : process (clk_125_in, shift_register)
begin
if clk_125_in'event and clk_125_in = '1' then
if ((shift_register(14 downto 5) = "1100010001") and (shift_register(4 downto 0) /= "11000")) THEN
synchronized <= '1';
else
synchronized <= '0';
end if;
end if;
end process sync_detect; So my questions are once again :). 1) From the data i get synchronized pulses every 44.1kHz. I would like to and have to make a clock from this, I even would have to if neccessary multiply it by 2 or 4 to get 88.2 or 176.4k for different modes. That's why i'm thinking about PLL. Can i simply put them in the PLL or should i do smth with them as kaz has written. 2) I had ocasionally problems with fan-outing this signal to the other parts of my design - i suppose that due to CDR there were some problems. Could i simply put there another signal like synchronized2 to double up the logic, but to get the second signal and not to mess with the synchronized? Or am i saying stupid things?:) best regards
