14 years agoClock problem
Hi All,
I am trying to reduce the clock frequency from 25 MHZ to 12.5 MHZ using VHDL. I also intend to implement this in hardware, however I am having a lot of difficulty with my code. I can not assign a new clock frequency to an output variable which I wanted to assign to an output pin. I am getting the following error for my code which is shown below: Error (10517): VHDL type mismatch error at clock.vhd(23): std_logic_vector type does not match integer literal My Code: -- Divide clock frequency by 2 -- Standard libary delarations library ieee; use ieee.std_logic_1164.all; -- define input and outputs for the entity entity clock is port( clk_in: in std_logic; clk_out: buffer std_logic; va: buffer std_logic_vector(2 downto 0) ); end clock; -- internal function of enetity architecture behave of clock is --internal variable signal count : integer :=1; begin process (clk_in,clk_out,va) begin -- Required in order to convert the sinewave to a square wave clk_out <= not clk_in; -- Check for rising edge of clock if(clk_out'event and clk_out='1') then --increment the count variable by 1 count <=count+1; -- when count is 2 if(count = 2) then --assign 1 to the variable which will be assigned to an output pin va <= 1; end if; end if; end process; end behave; Thank you in advance.12 Replies
sir your code is not working
Error (10482): VHDL error at clk200.vhd(2): object "std_logic" is used but not declared - Altera_Forum
--- Quote Start --- sir your code is not working Error (10482): VHDL error at clk200.vhd(2): object "std_logic" is used but not declared --- Quote End --- You still need to put in at the top: library ieee; use ieee.std_logic_1164.all In regard to this discussion, I'm surprised no one mentioned it, but I'd really design this as a module with 2 free-running counters that trigger each other; one to generate the "start" pulse at 1 Hz, and the other to generate the "long" pulse. Thinking of these as clocks just isn't a good idea.
