10 years agoClock constraints being ignored
I am working on a design on MAX V CPLD : 5M2210ZF324C5 on Quartus II 15.0 version.
I have a clock coming from one of the pins and I have create_clock constraint for this as shown below: create_clock -name {Cpld_Clk} -period 20.000 -waveform { 0.000 10.000 } [get_ports {Cpld_Clk}] However in the fitter report and sta report I get the following warnings: Warning (332174): Ignored filter at 12g_main_hp_mlk_top.sdc(148): Cpld_Clk could not be matched with a port Warning (332049): Ignored create_clock at 12g_main_hp_mlk_top.sdc(148): Argument <targets> is an empty collection Info (332050): create_clock -name {Cpld_Clk} -period 20.000 -waveform { 0.000 10.000 } [get_ports {Cpld_Clk}] Can anyone please tell me why the constraints have been ignored? Thank you3 Replies
Looks fine. It is case sensitive by default, so maybe that's it?
In TQ, go to View -> Name Finder, select get_ports and search on *. Does your port show up? If it does, keep fixing the wildcard until it matches just that one, although the reason will probably become apparent. If it doesn't show up, then I'm guessing this port was synthesized out of your design and it's an RTL/synthesis issue instead of a TimeQuest issue. - Altera_Forum
I think you also need a constraint specifying the pin it is connected to.
'Cpld_Clk' isn't a top level port in your design.
Do you have a signal called 'Cpld_Clk'? Is it being used as a clock? How is it generated? Cheers, Alex
