16 years ago
Can't connect to USB serial port with nios2-terminal
I have a Bemicro board, which includes a FTDI virtual com port, and I cannot connect to it using nios2-terminal under windows. The com port is COM4 and hyper-terminal works perfectly.
When I use "/dev/com4", nios2-terminal responds that there is no such file or directory. I checked and there is no "\dev" directory. I'm not sure if cygwin will handle this on the fly or not.
Can anyone help me out?
    --- Quote Start ---
    show result.
    --- Quote End ---
    Sorry, didn't work. Same error:
    $ nios2-terminal --uart --port=/dev/tty4 --baud-rate=115200
    nios2-terminal: can't open uart: No such file or directory
    I tried tty0 to tty5. I am trying to use COM4.
    No "dev" directory.
    $cd / && ls -a
    ./        COPYING.LIB*       Cygwin.bat*   bin/         etc/   tmp/
    ../       COPYING.LIBGLOSS*  Cygwin.ico*   cygdrive/    lib/   usr/
    COPYING*  COPYING.NEWLIB*    LICENSE.TXT*  cygreg.bat*  proc/  var/
    --- Quote Start ---
    --- Quote End ---
    Make
    --- Quote Start ---
    ls /dev/tty*
    --- Quote End ---
    and show result.
