16 years agoCan't connect to USB serial port with nios2-terminal
I have a Bemicro board, which includes a FTDI virtual com port, and I cannot connect to it using nios2-terminal under windows. The com port is COM4 and hyper-terminal works perfectly. When I...
16 years ago --- Quote Start --- I have a Bemicro board, which includes a FTDI virtual com port, and I cannot connect to it using nios2-terminal under windows. The com port is COM4 and hyper-terminal works perfectly. When I use "/dev/com4", nios2-terminal responds that there is no such file or directory. I checked and there is no "\dev" directory. I'm not sure if cygwin will handle this on the fly or not. Can anyone help me out? --- Quote End --- Make --- Quote Start --- ls /dev/tty* --- Quote End --- and show result.
