16 years agoCan't connect to USB serial port with nios2-terminal
I have a Bemicro board, which includes a FTDI virtual com port, and I cannot connect to it using nios2-terminal under windows. The com port is COM4 and hyper-terminal works perfectly. When I...
16 years ago --- Quote Start --- show result. --- Quote End --- Sorry, didn't work. Same error:
$ nios2-terminal --uart --port=/dev/tty4 --baud-rate=115200
nios2-terminal: can't open uart: No such file or directory
I tried tty0 to tty5. I am trying to use COM4. No "dev" directory.
$cd / && ls -a
./ COPYING.LIB* Cygwin.bat* bin/ etc/ tmp/
../ COPYING.LIBGLOSS* Cygwin.ico* cygdrive/ lib/ usr/
COPYING* COPYING.NEWLIB* LICENSE.TXT* cygreg.bat* proc/ var/
