15 years agoCan I exchange the positive signal (p) and negative (n) signal of LVDS?
Can I exchange the positive signal (p) and negative (n) signal of LVDS in Cyclone devices? In order to avoid the use of vias.
Extremely grateful.
--- Quote Start --- Is the LVDS clock signal can also be inverted inside the FPGA? --- Quote End --- You have to apply a phase shift. In my opinion, inverting the signals is good to fix layout errors, but I won't use it as regular design means. - Altera_Forum
Thanks for your help.
Is the LVDS clock signal can also be inverted inside the FPGA? - Altera_Forum
Yes.
Of course, you need to negate the signal inside your design. Important notice: you can't put the inversion between a DDRIO (or ALTLVDS primitive, which uses DDRIO) and the pin. So, if you're planing to use DDRIO or ALTLVDS, beware of that inversion.
