9 years ago
Browse the ram content
Hello everyone, i am doing image processing on fgpa.
Actually i want to browse the ram content for every row of the image, and whenever the content of the adress is not updated i need to register this adress. I placed the read statement in a for loop but if for example i have 5 adresses that their contents are not updated the output register only the last one. Is there a possible way to register the multiple adresses.
    It sounds like you are trying to make CAM - content addressable ram. This is not easy in an FPGA.
    Also, your code looks like software rather than hardware. for loops in HDL are unrolled to make parallel or sequential logic. In your case, it is create 8 comparators and a 8-1 mux to select the correct ram register (because it is not a ram, its a load of registers) to use.
    because you are muxing 8-1, comparing then muxing the result again in a single clock cycle, your Fmax is going to be very slow.
    The adresses are not incremented like this, actually they are ouputs from another block so it's like that they are random adresses. I can't tell when they are generated neither their value.
    --- Quote Start ---
    Yes i know this circuit is implemented in logic but i thought this the only way i can check the ram content. Is there a possible way to browse ram content and get multiple adresses as output without using a for loop? knowing that it's not necessary to get all this adresses in just one clock cycle.
    --- Quote End ---
    Yes
    Provide the addresses sequentially over several clock cycles using a counter.
    This code will not work in an FPGA. You can only access a single ram element per clock cycle. So this design will be implemented in logic.
    Using a loop the way you have is NOT good practice. For example, here, if two addresses are a match, then it is the last one that will output to q_a.
    Do you know what circuit you expect from this code? have you got a diagram of it?
    Actually i'm doing this project using VHDL as a description language. Here's my code
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.numeric_std.all;
    use ieee.std_logic_signed.all;
    use ieee.math_real.all;
    library std;
    entity active_tag is
        generic
            DATA_WIDTH : natural
        port
            clk        : in std_logic;
            addr_a    : in std_logic_vector(2 downto 0);
            addr_b    : in std_logic_vector(2 downto 0);
            data_a    : in integer;
            we_a,rd_en    : in std_logic := '1';
            we_b    : in std_logic := '1';
            q : out integer;
            q_a        : out std_logic_vector(DatA_WIDTH-1 downto 0);
            q_b        : out std_logic_vector(Data_WIDTH-1 downto 0)
    end active_tag;
    architecture rtl of active_tag is
        signal data1: std_logic_vector((DATA_WIDTH-1) downto 0);
        signal  add_a,add_b : integer range 0 to 7;
        -- Build a 2-D array type for the RAM
        subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0);
        type memory_t is array(7 downto 0) of word_t;
        -- Declare the RAM
        shared variable ram : memory_t;
    begin
    add_a<=to_integer(unsigned(addr_a));
    data1<=std_logic_vector(to_unsigned(data_a,data1'length));
        -- Port A
        process(clk)
        variable i : integer:=1 ;
        begin
        if(rising_edge(clk)) then
            if(we_a = '1') then
                ram(add_a) := data1;
            end if;
            if rd_en='1' then
                for add_a in 0 to 7 loop
                    if (ram(add_a)=(y-1 mod 3)) then
                        q_a<=std_logic_vector(to_unsigned(add_a,q_a'length));
                    end if;
                end loop;
            end if;
        end if;
        end process;
        -- Port B
        process(clk)
        begin
            if(we_b = '1') then
                ram(add_b) := "000";
                q_b <= addr_b;
            end if;
        end if;
        end process;
    end rtl;
    the entry data_a represent y mod 3 . For every row of the image i need to check all the ram content so whnever data_a is not changed i need to read this adress. To detect whether the entry is changed or not i compare it to y-1 mod 3 as you can see in the code. But the problem is that if there's multiple adresses that their contents are is not updated i get only the last adress it's like it is the only one that its content it is not changed.
    this is a little vague? is this is a software or HDL problem? why not post a code example?
