9 years agoBrowse the ram content
Hello everyone, i am doing image processing on fgpa. Actually i want to browse the ram content for every row of the image, and whenever the content of the adress is not updated i need to register...
9 years agoActually i'm doing this project using VHDL as a description language. Here's my code
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_signed.all;
use ieee.math_real.all;
library std;
entity active_tag is
generic
DATA_WIDTH : natural
port
clk : in std_logic;
addr_a : in std_logic_vector(2 downto 0);
addr_b : in std_logic_vector(2 downto 0);
data_a : in integer;
we_a,rd_en : in std_logic := '1';
we_b : in std_logic := '1';
q : out integer;
q_a : out std_logic_vector(DatA_WIDTH-1 downto 0);
q_b : out std_logic_vector(Data_WIDTH-1 downto 0)
end active_tag;
architecture rtl of active_tag is
signal data1: std_logic_vector((DATA_WIDTH-1) downto 0);
signal add_a,add_b : integer range 0 to 7;
-- Build a 2-D array type for the RAM
subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0);
type memory_t is array(7 downto 0) of word_t;
-- Declare the RAM
shared variable ram : memory_t;
begin
add_a<=to_integer(unsigned(addr_a));
data1<=std_logic_vector(to_unsigned(data_a,data1'length));
-- Port A
process(clk)
variable i : integer:=1 ;
begin
if(rising_edge(clk)) then
if(we_a = '1') then
ram(add_a) := data1;
end if;
if rd_en='1' then
for add_a in 0 to 7 loop
if (ram(add_a)=(y-1 mod 3)) then
q_a<=std_logic_vector(to_unsigned(add_a,q_a'length));
end if;
end loop;
end if;
end if;
end process;
-- Port B
process(clk)
begin
if(we_b = '1') then
ram(add_b) := "000";
q_b <= addr_b;
end if;
end if;
end process;
end rtl;
the entry data_a represent y mod 3 . For every row of the image i need to check all the ram content so whnever data_a is not changed i need to read this adress. To detect whether the entry is changed or not i compare it to y-1 mod 3 as you can see in the code. But the problem is that if there's multiple adresses that their contents are is not updated i get only the last adress it's like it is the only one that its content it is not changed.
