9 years agoBrowse the ram content
Hello everyone, i am doing image processing on fgpa. Actually i want to browse the ram content for every row of the image, and whenever the content of the adress is not updated i need to register...
9 years agoIt sounds like you are trying to make CAM - content addressable ram. This is not easy in an FPGA.
Also, your code looks like software rather than hardware. for loops in HDL are unrolled to make parallel or sequential logic. In your case, it is create 8 comparators and a 8-1 mux to select the correct ram register (because it is not a ram, its a load of registers) to use. because you are muxing 8-1, comparing then muxing the result again in a single clock cycle, your Fmax is going to be very slow.
