18 years ago
Blockram: RAM model read/write
Can someone point me out how I can read/write to the following blockram RAM model ?
I can read and write to external SRAM, but I am not able to make this work using blockram. Could someone help?
ENTITY vram8k IS
	PORT
		data		: IN STD_LOGIC_VECTOR (7 DOWNTO 0);
		rdaddress		: IN STD_LOGIC_VECTOR (12 DOWNTO 0);
		rdclock		: IN STD_LOGIC ;
		rden		: IN STD_LOGIC  := '1';
		wraddress		: IN STD_LOGIC_VECTOR (12 DOWNTO 0);
		wrclock		: IN STD_LOGIC ;
		wren		: IN STD_LOGIC  := '1';
		q		: OUT STD_LOGIC_VECTOR (7 DOWNTO 0)
END vram8k;
Instantiation:
	vram8k_inst : work.vram8k PORT MAP (
		data	 	=> v_data_sig,
		rdaddress 	=> v_address_r_sig(12 downto 0),
		rdclock	 	=> Clk_Z80,
		wraddress	=> v_address_w_sig(12 downto 0),
		wrclock	 	=> Clk_Z80,
		wren	 	=> vram_we_sig,
		rden	 	=> vram_re_sig,
		q			=> vram_q_sig
I have tried a lot, and at this time, I have the following assertions for read/writing to the memory:
	v_address_w_sig <= A - x"2000" when (A >= x"2000" and MReq_n = '0');
	v_address_r_sig <= A - x"2000" when (A >= x"2000" and MReq_n = '0');
	vram_we_sig <= Wr_n;
	vram_re_sig <= Rd_n;
	v_data_sig <= DO_CPU when (Wr_n = '0' and MReq_n = '0');
        DI_CPU <= vram_q_sig when (Rd_n = '0' and MReq_n = '0' and A >= x"2000");
What must be changed for this to work?
    It would be easier to have a design example, that contains the complete path from generating addresses, write data and control signals up to reading the data. From your post, I also don't see clearly, which step of the RAM access doesn't work as intended. This could easily be seen from a simulation, also a simulation would help us to understand the timing as achieved in the present design.
    I'm pretty sure that the intended operation can be performed with internal RAM if used correct.
    These seems to have worked very well:
    	-- Write into RAM
    	vram_wraddress_sig <= A - x"2000";
    	vram_wren_sig <= not Wr_n when (A >= x"2000" and A <= x"4000");
    	vram_data_sig <= DO_CPU;
    	-- Read from RAM
    	vram_rden_sig <= Rd_n;
    	vram_rdaddress_sig <= A - x"2000";
            DI_CPU <= vram_q_sig when (A >= x"2000" and A <= x"4000") else
    		         D_ROM when (Rd_n = '0' and MReq_n = '0' and A < x"2000") else
    Also, I am now able to write using a 3.58Mhz clock, and read at 25Mhz.
    However, I am very confused. The LPM model for ram have control signals asserted low:
    ENTITY vram8k IS
    PORT
    END vram8k;
    In my code, asserting write HIGH will write data. Asserting READ LOW will read data. something is very wrong here.... Is it me?
    I can't say anything about lpm_ram Megafunctions, I used altsyncram since Quartus V2, if I remember right. It has active high control signals, I would have thought the same of lpm_ram function, cause it's actually a wrapper of altsyncram, not inverting any signals as far as I see. Thus I guess, there is a misunderstanding of the basic operation of your design.
    You might want to change this snipet of code...
    to
    (A >= x"2000" and A < x"4000")
    otherwise you will be writing to ram when the address is x"2000" and x"4000".
