18 years agoBlockram: RAM model read/write
Hello, Can someone point me out how I can read/write to the following blockram RAM model ? I can read and write to external SRAM, but I am not able to make this work using blockram. Could...
18 years agoIt would be easier to have a design example, that contains the complete path from generating addresses, write data and control signals up to reading the data. From your post, I also don't see clearly, which step of the RAM access doesn't work as intended. This could easily be seen from a simulation, also a simulation would help us to understand the timing as achieved in the present design.
I'm pretty sure that the intended operation can be performed with internal RAM if used correct.
