Block Memory Pipeline Controls
Have an old design in a Cyclone V, and recently added a 2-port, single-clock block memory; the read side is used to stuff words into an Avalon-mm interface. So to accommodate wait states, and overcome the read latency of the memory (two clocks, one for input address, one for output data), I implemented both the rd_addressstall and rden pipeline controls. But, the rden seems to have no effect at all on the behavior of the read data port. I worked around it by omitting the dead data register from the block memory macro and simply adding a register external to the read data port, enabled by the same signal that was driving rden.
That works as intended and all is well; but I am curious about the intention of the rden control. How should it work?
- RichardT_altera
If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
- RichardT_altera
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
- RichardT_altera
You may checkout this user guide on how the rden signal works.
https://www.intel.com/content/www/us/en/docs/programmable/683240/17-0/read-enable.html
https://www.intel.com/content/www/us/en/docs/programmable/683375/current/embedded-memory-modes.html
Richard Tan
