15 years agoBidirectional buffer
I am working on Altera FPGA. Please help me to code a Bidirectional bus using HDL. Can anyone share a code for this. Regards, freak14 Replies
which HDL? AHDL, VHDL or Verilog?
For example, this could be a sample code for VHDL
(I wrote it without checking for syntax errors, be warned) entity io_buffer is port ( data_out : in std_logic_vector(WIDTH-1 downto 0); data_in : out std_logic_vector(WIDTH-1 downto 0); data_out_ena : in std_logic; io_data : inout std_logic_vector(WIDTH-1 downto 0) ); end io_buffer; architecture arch of io_buffer is begin bidir_buffer : process (data_out_ena, io_data) begin if (data_out_ena = '1') then io_data <= data_out; else io_data <= (others => '0'); end if; data_in <= io_data; end process bidir_buffer; end arch; - Altera_Forum
I think you meant
io_data <= (others => 'Z'); - Altera_Forum
Sorry. You are right, Tricky.
As I said I wrote the code without checking - Altera_Forum
Thanks Triky, Cris.
Can i use the same code if i target for FPGA and ASIC. My doubt is, do i need to modify 'Z' if using in either ASIC or FPGA. Regards, freak - Altera_Forum
You can use Z for either, since HDL simply describes how your system must behave.
Z means that signal is not driven, just like a tristate output. How the described function is actually synthesized into the device depends from the synthesis tool and on device cababilites: i.e. if the real device has tristate buffers available, a true tristate bus can be generated; otherwise the same behaviour could be implemented with logic gates if the bidir bus is internal to the device and other bus drivers are known. - Altera_Forum
Hi Cris,
If i have tristate buffers in my code, will Quartus-II automatically targets to Tristate buffers in Altera devices. Please comment. Regards, freak - Altera_Forum
It should do if you have followed the coding guidelines for tristate buffers. The modified code cris posted should be ok.
Note that FGPAs only support tri-state bufers for I/O signals.
There is no tri-state capability for internal signals. However, if you use tri-state driven internal signals, Quartus will try to reproduce the behavior using multiplexers. - Altera_Forum
Hi, I have a case similar to the code above. However, during gate-level simulation, while io_data has 'Z' values, data_in has 'X' value when data_out_ena is not '1'. What could probably cause the simulation to be behaving in this way?
