15 years agoBidirectional buffer
Hi, I am working on Altera FPGA. Please help me to code a Bidirectional bus using HDL. Can anyone share a code for this. Regards, freak
15 years agoFor example, this could be a sample code for VHDL
(I wrote it without checking for syntax errors, be warned) entity io_buffer is port ( data_out : in std_logic_vector(WIDTH-1 downto 0); data_in : out std_logic_vector(WIDTH-1 downto 0); data_out_ena : in std_logic; io_data : inout std_logic_vector(WIDTH-1 downto 0) ); end io_buffer; architecture arch of io_buffer is begin bidir_buffer : process (data_out_ena, io_data) begin if (data_out_ena = '1') then io_data <= data_out; else io_data <= (others => '0'); end if; data_in <= io_data; end process bidir_buffer; end arch;
