15 years agoBidirectional buffer
Hi, I am working on Altera FPGA. Please help me to code a Bidirectional bus using HDL. Can anyone share a code for this. Regards, freak
15 years agoYou can use Z for either, since HDL simply describes how your system must behave.
Z means that signal is not driven, just like a tristate output. How the described function is actually synthesized into the device depends from the synthesis tool and on device cababilites: i.e. if the real device has tristate buffers available, a true tristate bus can be generated; otherwise the same behaviour could be implemented with logic gates if the bidir bus is internal to the device and other bus drivers are known.
