17 years agobackspace and enter key, reset VGA in verilog HDL?
how to write codes for backspace and enter key in Verilog HDL?
and also how to reset VGA screen? here's the sample code i cant figure out what is wrong. thanks! module vga_sync( input wire clk, reset, output wire h_sync, v_sync, video_on, p_tick, output wire [9:0] pixel_x, pixel_y ); //constant declaration //VGA 640-by-480 sync parameters localparam HD = 640; //horizontal display localparam HF = 48; // h. back(left) porch localparam HB = 16; //h. front(right) porch localparam HR = 96; //h. retrace (sync a) localparam VD = 482; //vertical display localparam VF = 33; //v. back(top) localparam VB = 8; //v. front (bottom) localparam VR = 2; //v. retrace (sync a) //mod-2 counter reg mod2_reg; wire mod2_next; //sync counters reg [9:0] h_count_reg, h_count_next; reg [9:0] v_count_reg, v_count_next; //output buffer reg v_sync_reg, h_sync_reg; wire v_sync_next, h_sync_next; //status signal wire h_end, v_end, pixel_tick; //body //registers always @(posedge clk, posedge reset) if (reset) begin mod2_reg <= 1'b0; v_count_reg <= 1'b0; h_count_reg <= 1'b0; v_sync_reg <= 1'b0; h_sync_reg <= 1'b0; end else begin mod2_reg <= mod2_next; v_count_reg <= v_count_next; h_count_reg <= h_count_next; v_sync_reg <= v_sync_next; h_sync_reg <= h_sync_next; end //mod-2 circuit to generate 25Mhz enable tick assign mod2_next = ~mod2_reg; assign pixel_tick = mod2_reg; //status signals //end of horizontal counter (799) assign h_end = (h_count_reg == (HD+HF+HB+HR-1)); //end of vertical counter (524) assign v_end = (v_count_reg == (VD+VF+VB+VR-1)); //next state logic of mod-800 horizontal sync counter always@* if (pixel_tick) //25MHz pulse if(h_end) h_count_next = 0; else h_count_next = h_count_reg+1; else h_count_next = h_count_reg; //next-state logic of mod-525 vertical sync counter always@* if (pixel_tick & h_end) if (v_end) v_count_next = 0; else v_count_next = v_count_reg + 1; else v_count_next = v_count_reg; //horizontal and vertical sync, buffered to avoid glitch //h_sync_next asserted between 656 and 751 assign h_sync_next = (h_count_reg >= (HD+HB) && h_count_reg <= (HD+HB+HR-1)); //v_sync_next asserted between 490 and 491 assign v_sync_next = (v_count_reg >= (VD+VB) && v_count_reg <= (VD+VB+VR-1)); //video on/off assign video_on = (h_count_reg<HD) && (v_count_reg<VD); //output assign h_sync = h_sync_reg; assign v_sync = v_sync_reg; assign pixel_x = h_count_reg; assign pixel_y = v_count_reg; assign p_tick = pixel_tick; endmodule4 Replies
module VGA3 (clk, reset, ps2_data, ps2_clk, h_sync, v_sync,rgb);
input clk, reset; input ps2_data, ps2_clk; output h_sync, v_sync; output wire [2:0] rgb; wire [6:0] ascii_in; wire write_disable, write_enable; //reg Transmit_on; //localparam Enter_key = 8'h0A; // body // instantiate keyboard scan code circuit keyboard_code keyboard_controller_block_unit (.clk(clk), .reset(reset), .ps2_data(ps2_data), .ps2_clk(ps2_clk), .read_code(write_disable), .write_enable(write_enable), .ascii_code(ascii_in)); // instantiate top level vga display circuit top_vga_display_controller vga_display_controller_block_unit (.clk(clk), .reset(reset), .w_enable(write_disable), .ascii_in(ascii_in), .h_sync(h_sync), .v_sync(v_sync), .rgb(rgb)); /* always @* if(ascii_in == Enter_key) Transmit_on = 1; else Transmit_on = 0; */ //assign write_disable = ~Transmit_on; assign write_disable = ~write_enable; endmodule - Altera_Forum
module top_vga_display_controller(clk, reset, w_enable, ascii_in, h_sync, v_sync, rgb);
input clk, reset, w_enable; input wire [6:0] ascii_in; output h_sync, v_sync; output wire [2:0] rgb; // signal declaration wire [9:0] pixel_x, pixel_y; wire video_on, pixel_tick; /// reg [2:0] rgb_reg; wire [2:0] rgb_next; //// // body // instantiate vga_sync circuit vga_sync vga_syncronization_block_unit (.clk(clk), .reset(reset), .h_sync(h_sync), .v_sync(v_sync), .video_on(video_on), .p_tick(pixel_tick), .pixel_x(pixel_x), .pixel_y(pixel_y)); // font generation circuit text_pixel_generation_circuit text_pixel_generation_block_unit (.clk(clk), .reset(reset), .text_on(video_on), .w_enable(w_enable), .ascii_in(ascii_in), .pixel_x(pixel_x), .pixel_y(pixel_y), .text_rgb(rgb_next)); // rgb buffer always @(posedge clk) if (pixel_tick) rgb_reg <= rgb_next; assign rgb = rgb_reg; endmodule - Altera_Forum
`define MAXIMUM_H 80
`define MAXIMUM_V 30 //`define back_space 7'h7f module text_pixel_generation_circuit(clk, reset, text_on, w_enable, ascii_in, pixel_x, pixel_y, text_rgb); input clk, reset; input text_on, w_enable; input wire [6:0] ascii_in; input wire [9:0] pixel_x; input wire [9:0] pixel_y; output reg [2:0] text_rgb; // signal declaration //character rom wire [10:0] rom_address; wire [6:0] char_address; wire [3:0] row_address; wire [2:0] bit_address; wire [7:0] font_word; wire font_bit; // Synchronous Dual Port RAM Block declaration reg [6:0] ram [0:4095]; // RAM text buffer reg [11:0] write_addr; // RAM write address reg [11:0] read_addr; // RAM read address reg [4:0] write_row_address; // RAM write row //wire [4:0] write_row_address_next; reg [6:0] write_bit_address; // RAM write column //wire [6:0] write_bit_address_next; reg [6:0] read_data; // RAM read data reg [6:0] write_data; // RAM write data // tile RAM //wire we; //wire [11:0] address_r, address_w; wire [6:0] d_out; // cursor wire cursor_on; // delayed pixel count reg [9:0] pixel_x1_reg, pixel_x2_reg, pixel_x3_reg; reg [9:0] pixel_y1_reg, pixel_y2_reg, pixel_y3_reg; // object output signals wire [2:0] font_colour, cursor_colour; // instantiate character ROM character_rom character_rom_block_unit (.clk(clk), .address(rom_address), .data(font_word)); // registers always @(posedge clk) begin pixel_x1_reg <= pixel_x; pixel_x2_reg <= pixel_x1_reg; pixel_x3_reg <= pixel_x2_reg; //****** pixel_y1_reg <= pixel_y; pixel_y2_reg <= pixel_y1_reg; pixel_y3_reg <= pixel_y2_reg; //****** write_data <= ascii_in; write_addr <= write_row_address * `MAXIMUM_H + write_bit_address; read_addr <= (pixel_y >> 4) * `MAXIMUM_H + (pixel_x >> 3); read_data <= ram[read_addr]; if (w_enable) begin ram[write_addr] <= write_data; write_bit_address <= (write_bit_address == `MAXIMUM_H-1) ? 0 : write_bit_address + 1; write_row_address <= (write_bit_address == `MAXIMUM_H-1) ? (write_row_address == `MAXIMUM_V-1) ? 0 : write_row_address + 1 : write_row_address; end end // tile RAM read assign char_address = read_data; // character ROM assign row_address = pixel_y[3:0]; assign rom_address = {char_address, row_address}; // use delayed coordinate to select a bit assign bit_address = pixel_x3_reg[2:0]; assign font_bit = font_word[~bit_address]; // object signals // green over black assign font_colour = (font_bit) ? 3'b101 : 3'b000; assign cursor_colour = 3'b010; // use delayed coordinate for comparison assign cursor_on = (pixel_y3_reg [8:4] == write_row_address) && (pixel_x3_reg [9:3] == write_bit_address); // rgb multiplexing circuit always @* if (~text_on) //(text_on) text_rgb = 3'b000; else if (cursor_on) text_rgb = cursor_colour; else text_rgb = font_colour; endmodule - Altera_Forum
There is one typical syntax mistake commonly done.
assign h_end = (h_count_reg == (HD+HF+HB+HR-1)); You use == what is a logical equality its result can be unknown, you should better use === what is case equality and will only result in true or false assign h_end = (h_count_reg === (HD+HF+HB+HR-1)); Next thing. inside an always construct, you better use the non blocking assignment <= instead of the single =. Your code shows only the the video synchronisation signals, but no video information itself. No RGB signal shown, i assume this must be done somewhere else where the video_on signal is use ...
