17 years agobackspace and enter key, reset VGA in verilog HDL?
how to write codes for backspace and enter key in Verilog HDL? and also how to reset VGA screen? here's the sample code i cant figure out what is wrong. thanks! module vga_sync...
17 years agomodule top_vga_display_controller(clk, reset, w_enable, ascii_in, h_sync, v_sync, rgb);
input clk, reset, w_enable; input wire [6:0] ascii_in; output h_sync, v_sync; output wire [2:0] rgb; // signal declaration wire [9:0] pixel_x, pixel_y; wire video_on, pixel_tick; /// reg [2:0] rgb_reg; wire [2:0] rgb_next; //// // body // instantiate vga_sync circuit vga_sync vga_syncronization_block_unit (.clk(clk), .reset(reset), .h_sync(h_sync), .v_sync(v_sync), .video_on(video_on), .p_tick(pixel_tick), .pixel_x(pixel_x), .pixel_y(pixel_y)); // font generation circuit text_pixel_generation_circuit text_pixel_generation_block_unit (.clk(clk), .reset(reset), .text_on(video_on), .w_enable(w_enable), .ascii_in(ascii_in), .pixel_x(pixel_x), .pixel_y(pixel_y), .text_rgb(rgb_next)); // rgb buffer always @(posedge clk) if (pixel_tick) rgb_reg <= rgb_next; assign rgb = rgb_reg; endmodule
