17 years agobackspace and enter key, reset VGA in verilog HDL?
how to write codes for backspace and enter key in Verilog HDL? and also how to reset VGA screen? here's the sample code i cant figure out what is wrong. thanks! module vga_sync...
17 years ago`define MAXIMUM_H 80
`define MAXIMUM_V 30 //`define back_space 7'h7f module text_pixel_generation_circuit(clk, reset, text_on, w_enable, ascii_in, pixel_x, pixel_y, text_rgb); input clk, reset; input text_on, w_enable; input wire [6:0] ascii_in; input wire [9:0] pixel_x; input wire [9:0] pixel_y; output reg [2:0] text_rgb; // signal declaration //character rom wire [10:0] rom_address; wire [6:0] char_address; wire [3:0] row_address; wire [2:0] bit_address; wire [7:0] font_word; wire font_bit; // Synchronous Dual Port RAM Block declaration reg [6:0] ram [0:4095]; // RAM text buffer reg [11:0] write_addr; // RAM write address reg [11:0] read_addr; // RAM read address reg [4:0] write_row_address; // RAM write row //wire [4:0] write_row_address_next; reg [6:0] write_bit_address; // RAM write column //wire [6:0] write_bit_address_next; reg [6:0] read_data; // RAM read data reg [6:0] write_data; // RAM write data // tile RAM //wire we; //wire [11:0] address_r, address_w; wire [6:0] d_out; // cursor wire cursor_on; // delayed pixel count reg [9:0] pixel_x1_reg, pixel_x2_reg, pixel_x3_reg; reg [9:0] pixel_y1_reg, pixel_y2_reg, pixel_y3_reg; // object output signals wire [2:0] font_colour, cursor_colour; // instantiate character ROM character_rom character_rom_block_unit (.clk(clk), .address(rom_address), .data(font_word)); // registers always @(posedge clk) begin pixel_x1_reg <= pixel_x; pixel_x2_reg <= pixel_x1_reg; pixel_x3_reg <= pixel_x2_reg; //****** pixel_y1_reg <= pixel_y; pixel_y2_reg <= pixel_y1_reg; pixel_y3_reg <= pixel_y2_reg; //****** write_data <= ascii_in; write_addr <= write_row_address * `MAXIMUM_H + write_bit_address; read_addr <= (pixel_y >> 4) * `MAXIMUM_H + (pixel_x >> 3); read_data <= ram[read_addr]; if (w_enable) begin ram[write_addr] <= write_data; write_bit_address <= (write_bit_address == `MAXIMUM_H-1) ? 0 : write_bit_address + 1; write_row_address <= (write_bit_address == `MAXIMUM_H-1) ? (write_row_address == `MAXIMUM_V-1) ? 0 : write_row_address + 1 : write_row_address; end end // tile RAM read assign char_address = read_data; // character ROM assign row_address = pixel_y[3:0]; assign rom_address = {char_address, row_address}; // use delayed coordinate to select a bit assign bit_address = pixel_x3_reg[2:0]; assign font_bit = font_word[~bit_address]; // object signals // green over black assign font_colour = (font_bit) ? 3'b101 : 3'b000; assign cursor_colour = 3'b010; // use delayed coordinate for comparison assign cursor_on = (pixel_y3_reg [8:4] == write_row_address) && (pixel_x3_reg [9:3] == write_bit_address); // rgb multiplexing circuit always @* if (~text_on) //(text_on) text_rgb = 3'b000; else if (cursor_on) text_rgb = cursor_colour; else text_rgb = font_colour; endmodule
