nome's avatar
nome
2 years ago
Arria II GX configuration from CPLD
I am using the JS28F256M29EWH NOR Flash with only using 8-bit data and 25-bit address Parallel Flash in FPP mode. In my case, our flash 8-bits flash data pins are directly connected with fpga_config_data's 8-bit pins. Mostly, these pins I recognize are connected with CPLD, and another set of CPLD pins is connected with fpga_config_data for configuration.
I am following the instructions from ug_pfl.pdf to convert our .SOF to .POF. For NOR Flash programming, I am using the PFL Mega core IP in Mode "only Flash programming" from Arria II FPGA I check read back by using option bits
Now, I am attempting to configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II.
Please find the attached file.
The issue is that the code doesn't work. I am checking fpga_dclk and fpga_nSTATUS pins using an oscilloscope, but no activity is showing. This implies that there might be a problem with RESET_n and MAX_EN as given in the VHDL Codes.
Also, I have defined unused pins as "As Output Ground"
Please help me identify where I am making a mistake.
Nome
  • We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
    • nome's avatar
      nome
      I apologize for the delayed response due to my long vacations.
      Please find attached our configuration area schematic pdf .
      Could you please assist me in identifying any errors, such as incorrect addresses entities?
      I'm uncertain about the correctness of the configuration. also suggest us if i will consider PFL prallel flash loader
      Nome
  • Hi,
    Please provide the link to the Config_control code page so we can do the checking.
    Aiman
  • Hi,
    • Is JTAG working fine? (without config control codes)
    • Where did you get the Config control codes? Is it from Intel or other source?
    • Can you provide us your schematic?
    • nome's avatar
      nome
      Thanks for your Reply
      Is JTAG working fine? (without config control codes) Yes Excellent Working i can get CPLD and FPGA in quartus programmer even I can get Flash when I load as per our board pins assignment PFL (prallel flash loader) .sof file into FPGA can easily flash programming .
      Where did you get the Config control codes? Is it from Intel or other source? yes From Intel official site
      Nome
  • Hi,
    What do you mean by "configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II"? What is the reason on using Config_Control_Codes from Intel Altera Stratix II for Arria ii?
    What Quartus version do you used?
    Any error shows?
    Aiman
    • nome's avatar
      nome
      Thank you for your reply.
      What do you mean by "configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II?
      I am not utilizing PFL (parallel flash loader) due to the limited LE (logic element) blocks available, as the EPM240T100I5 CPLD has only 240 blocks. This restriction prevents the use of a higher-density CPLD.
      We need to allocate more space for various functionalities, aside from FPGA configuration. This is why we are using the official config_control_codes from Stratix, as indicated in the attached QAR file in my initial post.
      All specific pin requirements, such as fpga_addr, fpga_nSTATUS, fpga_dclk, and others, have been assigned according to our custom board specifications. However, the issue is that these codes are not working; when testing fpga_dclk from the oscilloscope, it remains low at all times.
      Nome
