Arria II GX configuration from CPLD
What do you mean by "configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II"? What is the reason on using Config_Control_Codes from Intel Altera Stratix II for Arria ii?
What Quartus version do you used?
Any error shows?
Aiman
Thank you for your reply.
What do you mean by "configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II?
I am not utilizing PFL (parallel flash loader) due to the limited LE (logic element) blocks available, as the EPM240T100I5 CPLD has only 240 blocks. This restriction prevents the use of a higher-density CPLD.
We need to allocate more space for various functionalities, aside from FPGA configuration. This is why we are using the official config_control_codes from Stratix, as indicated in the attached QAR file in my initial post.
All specific pin requirements, such as fpga_addr, fpga_nSTATUS, fpga_dclk, and others, have been assigned according to our custom board specifications. However, the issue is that these codes are not working; when testing fpga_dclk from the oscilloscope, it remains low at all times.
Nome
