Arria II GX configuration from CPLD
What do you mean by "configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II"? What is the reason on using Config_Control_Codes from Intel Altera Stratix II for Arria ii?
What Quartus version do you used?
Any error shows?
Aiman
- nome2 years ago
Thank you for your reply.
What do you mean by "configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II?
I am not utilizing PFL (parallel flash loader) due to the limited LE (logic element) blocks available, as the EPM240T100I5 CPLD has only 240 blocks. This restriction prevents the use of a higher-density CPLD.
We need to allocate more space for various functionalities, aside from FPGA configuration. This is why we are using the official config_control_codes from Stratix, as indicated in the attached QAR file in my initial post.
All specific pin requirements, such as fpga_addr, fpga_nSTATUS, fpga_dclk, and others, have been assigned according to our custom board specifications. However, the issue is that these codes are not working; when testing fpga_dclk from the oscilloscope, it remains low at all times.
Nome
