Arria II EP2AGX45CU17C6N power up failure.
Hi all,
I am using Arria II EP2AGX45CU17C6N FPGA in my PCIe interfacing card project, I had only one FPGA device mounted on PCB and power section. Power voltage rail on PCB board 3.3V & 0.9 (sw_reg - Dual O\P) | 2.5V (LDO) | | 1.5 & 1.1V (LDO - Dual O\P) On doing Initial power supply check in PCB only some FPGA VCC pins Receives voltage Vccio = 3.3V , Vcc =0.9V ,Vccl_GXB=1.1V,VccH_GXB=1.5V And VCCA=2.5V. but other pins like vcca_pll(2.5v),vcc_pll(0.9v) and vccb(1.5v) are open (isolated from getting powered by removing ferrite bead component on pcb) At this point I measured Voltage rail, all voltage output are fine and as per expected (no Heat on FPGA and regulators) After some time i mounted all the components and powered up the board so that other VCC and PPL pins also receives voltage VCCA_PLL (2.5V),VCC_PLL(0.9V) and VCCB(1.5V),At this time I found VCCB(1.5V) Pins got shot to GND pin also 1.5V LDO and FPGA got heat. I switched of Supply and check the impedance now VCCB pin of FPGA and GND Pin is Short (Z = 0 ohm), I came to know VCCB pin of FPGA got gone bad, my query, 1. Can i connect only some FPGA VCC pin to respective voltage initially (not connecting PLL and VCCB pins,. connecting these PINs second time power on)?? Will devices pin go bad on second power up?? 2. Should I connect all the power supply pin of FPGA including PLL and VCCB every time power up for device to work properly?? not to get spoil of any pins?? Note:- Last option... I might have received fault\damage FPGA but it’s my last option getting bad FPGA chip from standard manufacturing is very least possibilities...21 Replies
I have the same problem. Did someone found anything?
The device with not work properly if it doesn't get poser an all its supply pins. The POR circuitry will prevent the FPGA from starting. AFAIK it shouldn't do any permanent damage, but still I wouldn't recommend to do it.
Are you sure of your PCB? You could have connected some VCCB or VCC_PLL pins to ground by mistake. - Altera_Forum
Hi thanks,
I am sure and checked the VCCB and VCC_PLL pins are not shorted to gnd on my PCB.. also i check impedance of board after full PCB assyembly (Zo) it shows some value NOT SHORT to GND... Only on second time power up of board (fist time power to VCCB and VCC_PLL) these pins got short to GND (Zo=0)... I am analyzing the causal..????? since FPGA IC is costly getting one more IC's takes long time and process. And i afraid same issue could reflect on new one too...????????? - Altera_Forum
Are you sure your power supplies are working correctly? Do they produce the right voltage, and is there any overshoot at power up that could damage the FPGA?
Yes my power supply rail voltages are correct and most supplies derived from LDO except 3.3V and 0.9V...
Does Arria II EP2AGX45CU17C6N have any specific power sequencing…?? Can I power up VCC, VCCIO, VCCL_GXD, VCCH_GXB, VCCA first and after some time (adding ferrite filter component and) powering up VCCB, VCCA_PLL and VCCD_PLL voltage pins, along with initial supplies…?? I faced problem at second time power up ie. VCCB and VCC_PLL along with initial supplies… - Altera_Forum
No, as far as I know the modern Altera FPGAs are pretty forgiving with power sequencing. And even there, at worst it would lead to some startup problems, it shouldn't cause a short on some VCC pins. I'm sorry but if there indeed isn't any overshoot of some power lines at startup I don't see what could cause this.
Are you sure the short is in the FPGA itself and not the LDO or a filter between them? - Altera_Forum
Yes, I am sure the short is in FPGA vcc pins itself, neither in LDO , filter circuits etc.,
In fact I removed LDO,Filter(and associated passive connecting b\w FPGA and GND) still short persist. so, we removed FPGA from PCB and check the VCCB,VCCL_GXB and VCCH_GXB pin balls it Shown short to GND in multimeter. - Altera_Forum
The only reasons I know of that could explain these kind of failures are ESD and an overshoot on the power supplies. Some DC/DC converters that are a bit overcompensated can overshoot at startup and supply a voltage that is over the expected value for a short time, and this can destroy the FPGA.
Hello everybody,
I have a question, we have a similar problem on a few pieces of Arria II GX EP2AGX65DF25C6. After power up we found VCCA_PLL(2.5V) pins shorted to GND. Power supply rail voltages are correct and without overshooting. Power supplie 2.5V are derived from LDO and filtered. Thank you very much for your answer. - Altera_Forum
--- Quote Start --- Hello everybody, I have a question, we have a similar problem on a few pieces of Arria II GX EP2AGX65DF25C6. After power up we found VCCA_PLL(2.5V) pins shorted to GND. Power supply rail voltages are correct and without overshooting. Power supplie 2.5V are derived from LDO and filtered. Thank you very much for your answer. --- Quote End --- Hi, Is VCCA_PLL(2.5V) pins all De-Caps mounted before power up..??
