13 years agoArria II EP2AGX45CU17C6N power up failure.
Hi all, I am using Arria II EP2AGX45CU17C6N FPGA in my PCIe interfacing card project, I had only one FPGA device mounted on PCB and power section. Power voltage rail on PCB board ...
13 years agoAre you sure your power supplies are working correctly? Do they produce the right voltage, and is there any overshoot at power up that could damage the FPGA?
