13 years agoArria II EP2AGX45CU17C6N power up failure.
Hi all, I am using Arria II EP2AGX45CU17C6N FPGA in my PCIe interfacing card project, I had only one FPGA device mounted on PCB and power section. Power voltage rail on PCB board ...
13 years agoYes my power supply rail voltages are correct and most supplies derived from LDO except 3.3V and 0.9V...
Does Arria II EP2AGX45CU17C6N have any specific power sequencing…?? Can I power up VCC, VCCIO, VCCL_GXD, VCCH_GXB, VCCA first and after some time (adding ferrite filter component and) powering up VCCB, VCCA_PLL and VCCD_PLL voltage pins, along with initial supplies…?? I faced problem at second time power up ie. VCCB and VCC_PLL along with initial supplies…
