13 years agoArria II EP2AGX45CU17C6N power up failure.
Hi all, I am using Arria II EP2AGX45CU17C6N FPGA in my PCIe interfacing card project, I had only one FPGA device mounted on PCB and power section. Power voltage rail on PCB board ...
13 years agoHello everybody,
I have a question, we have a similar problem on a few pieces of Arria II GX EP2AGX65DF25C6. After power up we found VCCA_PLL(2.5V) pins shorted to GND. Power supply rail voltages are correct and without overshooting. Power supplie 2.5V are derived from LDO and filtered. Thank you very much for your answer.
