15 years ago
Are only MSBs outputted if bits are restricted?
Suppose I have a complex multiplier from the MegaWizard with inputs having 16 bits each and the outputs also having 16 bits. Because 16*16 equals 32 bits, would restricting the output to 16 bits output the Most Significant Bits (MSBs), i.e. would it output [31 downto 16] bits of the total 32 bits?
Also, would the above reasoning be the same for the altmult_add MegaWizard block too?
Is it common for all the Quartus arithmetic in general (to output the MSBs)?
If not, how can I force only the MSBs to be outputted?
Thank you.
