15 years agoAre only MSBs outputted if bits are restricted?
Hi, Suppose I have a complex multiplier from the MegaWizard with inputs having 16 bits each and the outputs also having 16 bits. Because 16*16 equals 32 bits, would restricting the output to 16...
15 years ago --- Quote Start --- Unfortunately, I am relatively new to VHDL and Altera Quartus, so I couldn't really comprehend your statement above... I was actually coding something along these lines: BEGIN PROCESS (clock) BEGIN IF (clock = '1') THEN FOR i IN 31 DOWNTO 0 LOOP IF datain(i) /= '0' THEN out_msb <= datain(i DOWNTO (i-15)); -->line 41
END IF; END LOOP; END IF; END PROCESS; END rtl; But compiling this gives me an error: "error (10453): vhdl error at msb_output.vhd(41): right bound (-1) of slice must belong to range (31 downto 0) of corresponding object" What I was trying to do is loop until I get the first '1' from the left, then take the 16-bits starting from the first '1' as my 16-MSB output. Help and guidance will be highly appreciated. --- Quote End --- In HDL, for loops are unrolled at synthesis time - loops do not exist on hardware. Whats happening here is that it's getting to i = 14 and then it tries to take the slice 14 downto -1. What the synthesisor is creating is a 32 to 1 mux with all the different inputs (31 downto 16), (30 downto 15) etc available, and then all the bits are put through logic gates to create select lines that select the appropriate 16 bit word. But as you've seen, your code tries to create and input to this MUX with an invalid range.
