15 years agoAre only MSBs outputted if bits are restricted?
Hi, Suppose I have a complex multiplier from the MegaWizard with inputs having 16 bits each and the outputs also having 16 bits. Because 16*16 equals 32 bits, would restricting the output to 16...
15 years agoUnfortunately, I am relatively new to VHDL and Altera Quartus, so I couldn't really comprehend your statement above...
I was actually coding something along these lines: BEGIN PROCESS (clock) BEGIN IF (clock = '1') THEN FOR i IN 31 DOWNTO 0 LOOP IF datain(i) /= '0' THEN out_msb <= datain(i DOWNTO (i-15)); -->line 41END IF; END LOOP; END IF; END PROCESS; END rtl; But compiling this gives me an error: "error (10453): vhdl error at msb_output.vhd(41): right bound (-1) of slice must belong to range (31 downto 0) of corresponding object" What I was trying to do is loop until I get the first '1' from the left, then take the 16-bits starting from the first '1' as my 16-MSB output. Help and guidance will be highly appreciated.
