15 years agoAre only MSBs outputted if bits are restricted?
Hi, Suppose I have a complex multiplier from the MegaWizard with inputs having 16 bits each and the outputs also having 16 bits. Because 16*16 equals 32 bits, would restricting the output to 16...
15 years agoWhen discarding most significant bits, you should use saturation logic to avoid overflow. For unsigned multiply, if any of the 6 bits on the left is set, the output should be forced to maximum value. For signed multiply, to min- or maxint, depending on the sign.
