16 years agoArbitrary Waveform
I need to improve the Linearisation of a VCO, For that i need to provide arbitrary waveform see attached between voltage 0 to 5VDC (it is like Triangle waveform but not the same). I think to insert the values to a PROM (look-up table) and with D/A the CPLD/FPGA will produce the waveform. Please advice. Regards, Doron5 Replies
Yes, I took as granted, that an external DAC would be necessary with any programmable logic device. 8-Bit amplitude resolution defines the number of data bits, a second design parameter is the number of LUT entries.
A CPLD must implement a ROM in logic cells, most smaller CPLD won't have enough resources to represent an arbitrary look-up table. But the logic is minimized by the design compiler, in some cases it may be sufficient. I suggest to define the table coding and let Quartus try to fit it to different CPLD. FPGAs have internal memory, that can be used as a ROM, so it's much easier with it. As another point, at low and medium speed, a PWM or SD modulator 1-Bit DAC can be used with a low-pass to generate the waveform. - Altera_Forum
You will need a D/A converter on the board - FPGA only have digital output pins.
if the voltage waveform is between 0VDC to +5VDC then lets calculate the resolution with 2^8: 5000mV/(2^8) = 19.5mV. This the voltage Resolution. Let me know if you need more data. Thanks, Doron - Altera_Forum
--- Quote Start --- Yes, it surely works. To select the design details, a specification for resolution, accuracy, speed would be useful. You also didn't mention what's the source of the control signal. --- Quote End --- The period of the waveform is 250uSec and it is cyclic. I would like that the Altera device will provide will provide this waveform or to put a D/A at the output of the device. Can CPLD Do the the job ? Please advice which simplified device will do the job ? Thanks, Doron - Altera_Forum
