16 years agoArbitrary Waveform
Hi, I need to improve the Linearisation of a VCO, For that i need to provide arbitrary waveform see attached between voltage 0 to 5VDC (it is like Triangle waveform but not the same). I ...
16 years ago --- Quote Start --- Yes, it surely works. To select the design details, a specification for resolution, accuracy, speed would be useful. You also didn't mention what's the source of the control signal. --- Quote End --- The period of the waveform is 250uSec and it is cyclic. I would like that the Altera device will provide will provide this waveform or to put a D/A at the output of the device. Can CPLD Do the the job ? Please advice which simplified device will do the job ? Thanks, Doron
