16 years agoArbitrary Waveform
Hi, I need to improve the Linearisation of a VCO, For that i need to provide arbitrary waveform see attached between voltage 0 to 5VDC (it is like Triangle waveform but not the same). I ...
16 years agoHi,
if the voltage waveform is between 0VDC to +5VDC then lets calculate the resolution with 2^8: 5000mV/(2^8) = 19.5mV. This the voltage Resolution. Let me know if you need more data. Thanks, Doron
