There is no requirement for a reset in a state machine. An initial value is good enough.
perhaps Tricky, you are right. but if you look better in code you find that there are 2 edges of clock instead of 1.
I don't like such bad time shifting that decrease setup times for outputs. Then i suggest one (AlanIsmail) should open MAxPlus help file and read carefully about coding style for AHDL.
