[Agilex]:Testing AVST Mode using HPS
Dear all,
Provide us the inputs to test AVST mode using HPS?
What are the files required for FPGA Configuration & HPS (U-boot & Linux) ?
We are using EMMC as booting device.
Thanks & Regards
Raju S
- aikeu
Hi raju1421,
I will close-pending this case if no further question.
Aik EU
- aikeu
Hi raju1421,
Referring to the document Overview block diagram to generate the jIC file:
For the GHRD, you will set the device configuration scheme for AVST and compile it in quartus.
The AVST works on the FSBL only but not the SSBL. When generating the .jic file for flashing the qspi flash change the mode to AVST setting according to the configuration scheme instead. Example: -o mode=AVSTX32
Aik Eu
- aikeu
- aikeu
Hi raju1421,
Can check out the below document related to Avalon ST application for Agilex.
https://www.intel.com/content/www/us/en/docs/programmable/683673/21-3/avalon-st-configuration.html
Aik Eu
- raju1421
Hi @aikeu ,
We are using Intel® Agilex™ F-Series Transceiver SoC Development Kit,
But in the below link there are steps for AS mode not for AVST mode.
Agilex 7 SoC With eMMC Storage On HPS | Projects | RocketBoards.org
Thanks & Regards
Raju S
