raju1421
3 years ago[Agilex]:Testing AVST Mode using HPS
Dear all, Provide us the inputs to test AVST mode using HPS? What are the files required for FPGA Configuration & HPS (U-boot & Linux) ? We are using EMMC as booting device. Thanks & Regards Raj...
aikeu
3 years agoHi raju1421,
Referring to the document Overview block diagram to generate the jIC file:
For the GHRD, you will set the device configuration scheme for AVST and compile it in quartus.
The AVST works on the FSBL only but not the SSBL. When generating the .jic file for flashing the qspi flash change the mode to AVST setting according to the configuration scheme instead. Example: -o mode=AVSTX32
Aik Eu
