Agilex 7 F Series Transceiver Pins Allowed Voltages During Powerup/When Unpowered
- 6 months ago
Yes, there is no footnote about the refclk but they can be driven when unpowered as long as there is proper coupling and the voltages are in the specified limits.
Thank you! I had not noticed the footnotes regarding hot swap on the FGT receivers before. As you comment, I see footnote 97 explicitly calls out the Vin pk-pk for the receviers applies when the part is unpowered.
Yes in our application, all lines will be AC coupled.
The same footnote about driving lines unpowered does not exist for the FGT REF_CLK inputs (unless I'm missing it), but it seems safe to assume that similar unpowered rating applies to the REF_CLK input as well?
