Milan_S's avatar
Milan_S
9 months ago
Agilex 5 input termination differential
After switching from Quartus 24.3.1 (Build 102) to Quartus 25.1.1 (Build 125), I encountered an issue with signal integrity on my hardware. Differential pairs operating at 400 Mbps (_P/_N) are defined as 1.3 V True Differential Signaling with Input Termination – Differential enabled. This configuration works correctly in Quartus 24.3.1. We verified signal integrity using a specialized oscilloscope with a differential probe. As expected, enabling or disabling termination in the Assignment Editor had a significant impact on the signal shape.
However, in Quartus 25.1.1, applying the same configuration does not affect signal integrity. The signal appears as if termination is always disabled, regardless of the ON/OFF setting for Input Termination – Differential.
Is there a change in how differential I/Os with termination should be defined in Quartus 25.1.1? Or is this a potential issue in the new version? All my assignments show OK status, and there are no warnings related to these settings in the design (Ignored Assignments).
