Serge93's avatar
Serge93
1 year ago
Agilex 5 GTS Reset Sequencer Intel FPGA IP : what value to set to i_refclk_bus_out with a PCIe IP ?
Using a PCIe IP in Root Port on a AGILEX 5, I have to use the GTS Reset Sequencer Intel FPGA IP configured in PCIe.
With Quartus 2025.1, the i_refclk_bus_out port appears on the GTS Reset Sequencer Intel FPGA IP.
There is no port on the PCIe IP to connect to port i_refclk_bus_out.
So, to which signal or to what value the port i_refclk_bus_out must be connected ?
Serge
  • Serge93's avatar
    Serge93
    Hello Wincent,
    Not for the moment, I am still busy with AGILEX 7-I-R-Tile.
    I will come back to you afterwards.
    Thnak you.
    Serge
    • Wincent_Altera's avatar
      Wincent_Altera
      Hi Serge,
      Do you foresee you will take more time to work back on this ?
      IF yes, can I get your help to file a new thread in future when you work back on Agilex5 project ?
      Because if the forum keep idling for too long, I will not longer receive any notification on that, it will get me to lost trace the record.
      Please be understand that we are in full commitment to ensure your success.
      Wincent
      • Serge93's avatar
        Serge93
        Hello Wincent,
        Yes it takes longuer than expected on AGILEX 7, so please close this case and I will come back to you when ready on AGILEX 5.
        Thank you for your help.
        Serge
    Wincent_Altera
    Hi Serge,
    Is there anything else you think I could provide in this forum thread ?
    Wincent_Altera
    Wincent_Altera
    Let me know if you need more time to response to this cases.
    Wincent_Altera
    • Serge93's avatar
      Serge93
      Hello Wincent,
      Monday was off in France.
      I could not answer to you because Quartus failed with the following error message :
      Quartus 2025.1 fails when using the PCIe IP (GTS AXI Streaming IP) :
          Error(24542): VHDL error at gts_axi_streaming.vhd(2001): expression has 20 elements; expected 22
      I have a project test case to reproduce the problem.
      Are you able to work on this problem ?
      Thnaks.
      Serge
        Wincent_Altera
        Hi Serge,
        Is it possible to attach the design .qar file here ?
        Let me check if I can help to resolve this or not.
        Wincent
    Wincent_Altera
    Hi ,
    The i_refclk_bus_out is an input signal/reference clock who indicate the fail status signal from GTS PMA/FEC direct PHY FPGA IP or for other IP exclude PCIe IP.
    If refer to https://www.intel.com/content/www/us/en/docs/programmable/813966/25-1/reset-signals.html
    IF this is something that will causing the compilation to be fail, you may connect something call "refclk_bus_out" from non PCIe IP to the GTS Reset Sequence IP.
    Wincent
    • Serge93's avatar
      Serge93
      Hello Wincent,
      Thank you for your answer.
      To be accurate, I can leave the port input i_refclk_bus_out floating without setting it to 0 or to 1, correct ?
      Serge
        Wincent_Altera
        Hi Serge,
        Theoretically Yes, as mentioned the clock is use for indicate the fail status signal from GTS PMA/FEC direct PHY FPGA IP or for other IP exclude PCIe IP.
        If there is no anything to monitor , you can let it be floated, I never try this implementation before.
        In cases the compilation is fail, please connected to any other IP who contain "refclk_bus_out/any similar"
        Wincent_Altera
