Agilex 5 GTS Reset Sequencer Intel FPGA IP : what value to set to i_refclk_bus_out with a PCIe IP ?
Let me know if you need more time to response to this cases.
Wincent_Altera
- Serge931 year ago
Hello Wincent,
Monday was off in France.
I could not answer to you because Quartus failed with the following error message :
Quartus 2025.1 fails when using the PCIe IP (GTS AXI Streaming IP) :
Error(24542): VHDL error at gts_axi_streaming.vhd(2001): expression has 20 elements; expected 22
I have a project test case to reproduce the problem.
Are you able to work on this problem ?
Thnaks.
Serge
- Wincent_Altera1 year ago
Hi Serge,
Is it possible to attach the design .qar file here ?
Let me check if I can help to resolve this or not.
Regards,Wincent
Hi @Serge93 ,
Below is my design for i_refclk_bus_out clock - ON the GTS Reset Sequencer Intel FPGA IPthe compilation pass as well
I attach the design .qar file here, please have a look.
Let me know if I could better assist you in anyway. Hope we can solved this.
Wincent
