Agilex 5 GTS Reset Sequencer Intel FPGA IP : what value to set to i_refclk_bus_out with a PCIe IP ?
Let me know if you need more time to response to this cases.
Wincent_Altera
Hello Wincent,
Monday was off in France.
I could not answer to you because Quartus failed with the following error message :
Quartus 2025.1 fails when using the PCIe IP (GTS AXI Streaming IP) :
Error(24542): VHDL error at gts_axi_streaming.vhd(2001): expression has 20 elements; expected 22
I have a project test case to reproduce the problem.
Are you able to work on this problem ?
Thnaks.
Serge
- Wincent_Altera1 year ago
Hi Serge,
Is it possible to attach the design .qar file here ?
Let me check if I can help to resolve this or not.
Regards,Wincent
Hi @Serge93 ,
Below is my design for i_refclk_bus_out clock - ON the GTS Reset Sequencer Intel FPGA IPthe compilation pass as well
I attach the design .qar file here, please have a look.
Let me know if I could better assist you in anyway. Hope we can solved this.
Wincent- Serge931 year ago
Hello Wincent,
Sorry I was busy yesterday.
Please pay attention the GTS PCIe IP must be configure in Root Port and not in End Point.
If you modify the GTS PCIe IP in Root Port in your project, I am pretty sure you will get the error.
Please find attached my test case.
Thanks for help.
Serge
