Advantest / Jabil Penang _Reject part returns under FPGA - MPN: 10M16SAU169C8G
Hi Intel Folks, @Farabi
Jabil manufacturing line found 9pcs MPN: 10M16SAU169C8G FPGA component with failure symptom :"unable to program" , 3.3V short to ground.
Please kindly advise how are we going to perform the reject parts return.
Its urgent case. Need response ASAP.
- NurAiman_M_Intel
I believe you should received an email containing all those information. Please check your email [email protected] and look for this title IN2511-0141 .
It has all the shipping address and other information that you will need to do. Kindly respond to the email for any further inquiries regarding this FACR.
Aiman
- NurAiman_M_Intel
This is to let you know that the FACR has been approved with ID CI2511-9155. By right, you should have received the confirmation email. Kindly be noted that only four devices were approved to be send to Factory. Please double check device that were approved and only send those four.
Also, kindly share the tracking number in here once the device has been shipped.
I will send you separate forum email for another information regarding this RMA, just FYI.
Aiman
- Junyi_yap
Hi @NurAiman_M_Intel ,
Thanks for the reply. I will request my internal team pack the 4pcs FPGA first.
Can you share me up front the shipping address, or any forwarder info, or any shipment info ?
- NurAiman_M_Intel
Without knowing the project revenue it will be hard for us to approve the FACR.
Aiman
- Junyi_yap
Its due to Jabil business policy.
If you need to numbers for justification, I only can tell you a rough figure for revenue - USD 300 million + / quarter.
- NurAiman_M_Intel
I did email you through forum email as it require some private information. Can you kindly response to the email?
Aiman
- Junyi_yap
Please refer to below reply and attachment of photo.
Customer Name: Advantest
Development Board: <please fill in>DCN and DCL
Project Name: <please fill in> Native DCDC
Project Status: (Design in / Design Commit / Prototype ?) <please fill in>Mass Production
Target Production Date: <please fill in>NA
Project Value / Revenue ($/Year): <please fill in>NA
Quartus Version being used: <please fill in> 21.1
Software patches (if any): <please fill in> NA
- NurAiman_M_Intel
Any update for this case?
Aiman
- Junyi_yap
Very sorry to say we dont have any screen shot provided. Its fail during our customer manufacturing functional test . We only know the content of FPGA not able to program, then our debug team replace new FPGA and those boards able to pass test.
Please kindly help for return the parts for FA. This case is dragging for too long time.
- NurAiman_M_Intel
I have respons to you through private message. However we are required to investigate the failure symptom as you mention:
The only failure symptom is FPGA fail to program during our manufacturing test.
What is the failure message/error message? Can you please send us the screenshot of the error message.?
Aiman
- NurAiman_M_Intel
Thank you. I have forwarded all the information for FACR. Will keep you updated.
Aiman
- Junyi_yap
Any update or good news for the FACR? We are request this since 20th Jan. Its almost one month for this case.
- NurAiman_M_Intel
Can you also answer below?
1- What is the failure symptom? Please elaborate the failure symptom in detail.
2.- When did the failure happen?
3.- How did you discover the failure?
4.- In which part of your process did you found the issue (Lab, production, quality, etc.)?
4.1- Was the device already in Field? For how long?
5.- How many units failed and how many units were used/tested by you?
6.- How did you determine the failure? Please elaborate the procedures.
7.- Does the failure unit was ever working before failure? If yes, how long had it been in use?
8.- How did you rule out that the failures were not caused by an electrical over stress (EOS) or an Electrostatic discharge (ESD)?
9.- What are your expectations of this failure analysis?
10.- Have you Re-ball your device? If yes, Is it lead-free reballing?
11.- Please add pictures of the device from the top and the bottom.
Aiman
- Junyi_yap
Hi @NurAiman_M_Intel ,Hi,
During our manufacturing functional test.
When we program the FPGA.
Production
Nope, the FPGA is brand new part.
9 pcs fail out of total 300pcs tested.
Nope, the reject part is constantly fail.
Our production line go through similar process and handle with same method.
Get the Root cause and FA to confirm why the FPGA fail to program.
Nope. There is not needed for re-ball.
Sorry to said that we already quarantine the reject part and its not possible to pull the part out from quarantine area.
- XINBAIYIJACK
Jabil?
- NurAiman_M_Intel
Any update? Have you fill in the DPR form?
Aiman
